talon tail lights swap to eclipse tail lights
keep in mind you cant just unbolt your and put up the eclipse one. The supports are different. look at the back of your talon. see how it dips down in the middle? the bracket is right there. the eclipse bumper doesnt dip at all. the bracket is up higher. also the side brackets are higher on an eclipse. you have a few choices when it comes to the brackets tho. you can either take the brackets off and move em up. or you can do as a friend of mine did, weld some long ass bolts into the holes, weld nuts below where the bumper will be and then just put nut on top to hold the bumper in place. I know it seems half-ass, but his has been that way for about a year and it holdin up just fine. also, you will need new tail light pig-tails, the ones from your talon wont fit into the sockets on the eclipse lenses. If you have any other questions just ask, ive done this conversion probly 5 times.
