Talon ECM interchange question
lofreqq
Jul 24, 2010
Mansfield, Pennsylvania
1995 Talon 420A non turbo automatic
I need an ECM for this car....does it have to be an exact match on the ID number or will other ones work and if so, which ones.... Thanks !!!
95-96 420a AUTO ECU only, Manual will not comunicate with your TCM. Not sure if '97+ will even plug in but they deffinately wont run the car without re-pinning the connectors, they are not even close on wire pinnouts. But the ECUs do not even look similar between a '96 and '97+
Ok.........one question.... i know the plugs for the sensors are different from the 95 to the newer ones, will the plugs be the same for the computer ?
Thanks for the help !!
Should have read that first, Thanks !!
  • Wanted 6 bolt NT water pipe
    • chrisman287
