taking off fender
awd4u
90
May 17, 2010
london, ON, Canada
hey guys, i was wondering how is a fender taken off of a 92 talon? and how hard is it? thanks.
I have a 2g but it should be similar to a 1g. I think in total there are about 10 bolts. There is the bolts at the bottom of the fender, the top of the fender and there is a bolt inside the wheel well, as well as the bolts attaching the bumper to the fender. The one inside the wheel well is the one that all ways give me problems. Job takes at most an hr if you have a problem, if not 10-15 min.
10-12 mm socket 3 and 6 in extension, and wrench.
Man this is pretty straight forward just by looking at it and taking the bolts out you see. If i recall correctly
5 bolts in the engine bay, the most obvious ones
4 bolts total in the wheel well, 2of these are mentioned below as well
2 bolts that hold the fender to the bumper
2 or 3 bolts that hold the fender to the body behind the head/corner light
4 bolts that hold the front "ground effect" piece on(yours will have the chrysler symbol on it)
2 bolts under that piece up under the car
1 bolt you get to when you open the door between the hinges
I think thats it, spray them all well and let them soak and do it again or they will break.
alright will do!
one more question, do i have to take off the front bumper?
