Tail lights
river
282
Jun 9, 2004
Anchorage, Alaska
I have a 1995 Eclipse GSX and im having an issue with the left rear tail light not working. I know the bulbs are good and there is power coming to them because when i turn on my lights both sets of lights in the rear illuminate. however if i brake, only the right brake light will illuminate whether or not the cars "night driving lights" are turned on or off. the turning signal acts the same way. when i activate my aftermarket alarm system the turning signal flashes but if i turn on my turning signal the bulb does not work. any ideas? i think that it has something to do with the alarm install, but the people that did the work on it say the alarm is fine and i have a short somewhere in my braking light system along with my turning signal system. has anybody had this problem on a car without an aftermarket alarm system?
I would first check to see if you have the correct bulbs in the correct locations. Next, I would check the contacts of the bulbs and the sockets for corrosion/poor conductivity. Your alarm activates the parking light (dimmer) filament portion of the bulb. The turn signal and brake use the brighter filament. From what you describe, it does sound like you have a short somewhere, but you should check those two items first.
however if i brake, only the right brake light will darken
I don't quite understand what you mean there.
  • For sale 4G63 NEW Stop Tech Drilled And Slotted Rotors
    New Stop Tech Drilled & Slotted Rotors $70 + shipping and paypal fees* FITS * Eclipse GST...
  • For sale 2g 2G GSX/GST Manual Transmission Steel & Poly Mount
    2G GSX/GST Manual Transmission Mount (Steel & Poly) $45 + shipping and paypal feesYou must be...
    • sanmantsi72
    • El_marto
  • For sale 1G DSM 4G63 PARTS
    • The_Partout_Spot
