Tach not working?? help
Asimmons90GSX
118
Sep 5, 2007
West Columbia, South Carolina
Well recently we just put my brother's motor into my 1990 Laser turbo chassis. When I parked the car about 2 years ago ALL the guages worked perfectly fine. So when we went to fire up the car we noticed the tach was not moving. Reving made no difference. We do have the MAF translator setup on his car so we checked where we tapped for the rpm signal on the cam angle sensor and everything was fine. Nothing changed. So then we tried another guage cluster and got the same result. So what could be causing the tach not to work? I've heard of broken tach's on 1G's but never have researched enough to know how to fix it. Any ideas??
its by the fuel rail. i acutaly had the same problem about a week ago where my tach decided to stop working.. the red wire i think i dont remember was loose inside the clip and casued the tach to stop working.
Ya ok I know what your talking about. I'll check that out and see if I can get that thing to work. Thanks guys
Did your tach stop working RIGHT after your translator install?
Mine did the same thing.
The translator pulls a 12v signal but the tach signal only provides I think a 9v signal (someone please feel free to correct those if they're wrong!)
I'm unsure of the exact values. But it's because your translator is pulling all the signal for your tach. It doesn't matter if you tap in at the ECU or the transistor.
did you try looking at the fuses under the dash?
That's why I asked if the other gauges were working... been there done that. Mine wasn't a blown fuse, just a loose one. Try wiggling it and the needles should jump, if that's the problem.
