T3 .63 vs FP T31 turbine housing
OMFGeofffff
Sep 11, 2008
Burnsville, Minnesota
Which would you choose? I have a AGP dbb 50trim with the t3 housing on it currently. Is it worth it to change to the fp housing? Its not installed or anything so its not like I'm changing my entire setup. I'm basically trying to piece everything together for the install. So I have 2 options....
1. Keep t3 housing and find manifold/wastegate/o2 housing.
2. Get FP housing/o2 housing and find wastegate.
Which will yield best airflow? If I went option 2 I'd most likely go with a evo 3 or fp manifold down the road.
