T-25 to OFH Fittings
What thread size? the thread size for the oilfilter housing, the hole in the front is:
3/8 BSPT, but most of the fitting you will buy are 3/8 npt, you will need to retap it or get a proper fitting.
The rest looks like an AN 4 line
Available in 10mm, 12mm and 14mm.
10mm x 1.25mm : Fits 1990-1994 DSM Turbo oil feed line to head
12mm x 1.25mm : Fits all 14b, 16g and 20G TDO5 Turbochargers
14mm x 1.5mm : Fits all Mitsubishi and Garrett Coolant Lines Turbochargers.
Also, make sure you have a proper restrictor for the turbo, if you are feeding it from the oil filter housing. http://www.dsmtuners.com/forums/tur...p-over-100psi-oil-pressure.html#post152093814
