SwayBar Endlinks.
AiR
314
Apr 7, 2003
Portland, Oregon
Well ive been hearing a clunking noise in my front end and torn every damn thing apart thinking that it was something in the shocks/ball joints/control arms. Finally a gave up and took it to les schwaub to see if they could figure anything out. Well they came to the conclusion that my swaybar endlinks are worn and they are loose nuts on the end and cant be tightend.
I did some searching on here and on some vendors sites but couldnt come up with any results on where i can find a good quality aftermarket piece to go in place of the stock ones. Anyone know a place that sells these? its for the front btw, Thanks.
Probably nobody sells an aftermarket piece because it's a simple part and there's not really any improvement to be made. Unless you want one made out of titanium or something to save a few ounces. Just go for the OEM ones. If I recall correctly, they're like $20-$30, or maybe less. I know the fronts are more than the rears for some reason, even though they look about the same.
They do corrode pretty easily, probably mostly because of their position. My car only spent a few winters in the North East, and I had a hell of a time getting those off when I started changing out suspension stuff. One of them I had to cut off the nut was so frozen. But I only had problems with the passenger side ones. I guess those get hit with more snow/salt.
I just replaced one of mine. You have to get them from Satan. Noone else makes them or has them. I think they were no more than $40.
