New Endlinks
Pro3racer
549
Nov 26, 2004
Stevens Pt./UW-Whitewater, Wisconsin
I was forced to cut my stock endlinks off my old swaybar when trying to install my RMDSMbar, and now i can't find new ones. My local dealer can only get the rebuild kit, not the actual hardware. I was seeing prices from other people around 30 bucks, is that for one, or for both? Rear endlinks BTW.
I made a set using 5/16 rod ends and urethane sway bar bushings. I don't have access to a digital camera to show you, unfortunately. I do know that you can get the rod ends from Mc Master Carr, and almost any 5/16 id. rubber or ure. bushings should work. One thing to note though, the rod ends are a bit short so it's tough to start the nuts. Hope that helps.
I was given the idea of using endlinks off other cars, like a nissan maxima. The guy told me that endlinks are pretty much endlinks they should work? Any info on this idea?
I HATE the endlinks on DSMs! i don't know who designed that crap but i think they deserve a good kick in the balls. They never come off right and the nut they have on inside is some size that doesn't exisist, a 14mm is too lose and 13 to small and theirs no standard one that will work. :mad: I just had to spend $80 for new rear ones myself......
Napa sells them cheap for a 2g, its worth checking to see if they have them for a 1g.
