sway bar for my 98 esi
talon84
Apr 19, 2005
metro, Minnesota
hey iv got a 98 talon esi w/o a factory sway bar in the rear and was wondering if you seasoned dsmers would give me some pointers on the correct route to take regarding this modifucation.... and also there is talk of needing an extra install kit because of the fact that there was no oe rear sway. also i dont plan on putting in a 3in exhaust so we dont have to worry about clearence.....thanks..... :talon:
youll need gst/gs lower control arms, sway bar endlinks and mounting brackets along with the miscellaneous nuts and obviously the sway bar of your choice. All will cost you about 150 for all the parts brand new or even cheaper if you can get them from a junk yard. The install is easy, I did the swap in about an hour and its pretty straight forward. Since Sway bar choice will also depend on how the exhaust routes through the rear cross member. If it routes the same as oem then pick any sway bar you want such as ST, Intrax, addco but if your exhaust goes under the cross member then the rear bar is just limited to Rm racing sway bars.
  • For sale 2g 2g Talon drivers side airbag
    Drivers side 95-98 Talon airbag. Excellent condition. Can ship UPS ground. Message...
  • For sale 2g 2g Talon tail lights.
    Pair of 2g OEM Talon tails. Decent condition. Not show quality. Right has a section on bottom...
  • Wanted [WTB] Hyundai 4g63 inner valve cover bolts
    Looking to source inner valve cover bolts for a Hyundai 4g63 valve cover
    • TheDude236
  • For sale 2g VRSF 2g FMIC.
    Bar and plate. 28x10x3.75. 2.5 inlet and outlet. 36.5 on center inlet and outlet Pretty...
  • For sale 2g Eclipse/Talon Passenger Side Fenders
    95-99 Eclipse/Talon Passenger Side Fenders
    • Sdcryan1
