swapping trannys ( what will fit)
You can use an Avenger,Talon,Eclipse, Neon with a 420A.
But you have to swap the bell housing, on the older neon transmissions.
http://www.dsmtuners.com/forums/420a-drivetrain-tech/167456-neon-eclipse-tranny-swap-merged-9-9-trans-transmission-nt-n-t.html
Neon transmission reference guide.
http://www.neons.org/forumdodge/trans.htm
The gear ratio will make your car feel a little slower and you will get better gas mileage.
Supposedly it will help turbo spool speed, if you ever go turbo on the car.
But I bought a TSI, instead of turbocharging my 420A.
2nd gen trannys for second gen cars dsms.
^ Not very helpful.:toobad:
Thanks a ton, and yes I will be putting a turbo on this summer looking at possibly a hahn system, but there site is down right now.
Now to find a tranny LOL.
I recommend getting a 2001+ neon 5 speed, because the switched over to hydraulic clutches.
And you won't have to swap bell housings.
I used a 2002 neon transmission, found it at a junkyard with only 8,000 miles on it.
was just about to ask if you know what year I can use up to.
Sorry to revive this thread but i wanted to ask, even if you changed the trans to a 1995-up would the bell housing bolt up to the 420A even tho its a cable clutch assembly? also wouldn't it be easier to install with it being a cable clutch?
i bought a 1st gen talon with a 4g 63motor and i am trying to swap the trans into my 2nd gen eclipse with the same motor my mechian said they have different size torque converter's does it sound right and can you swap them out?
The tranny won't bolt into the 2g. There are no holes for front and rear tranny mount brackets. The electronics are different also.
  • For sale 4G63 91 to 96 Auto T Case
    91 to 96 Auto T Case $195 + shipping & paypal feesYou must be registered to see element.You...
  • For sale 2g 2G 7 Bolt Cylinder Head
    2G 7 Bolt Cylinder Head $250 + shipping & paypal fees* deck surface measured measured at 5.20...
  • For sale Turbosmart Ultragate 38mm Gen V
    Brand new in box 2bolt flange waste gate, I no longer need this. Price is shipped in the states...
    • GST2012GSX
  • For sale 4G63 4G63 6 bolt -GM trans adapter plate
    4G63 to GM trans adapter plate. 350/400 turbo. 700r4. Gm manual bellhousings of same era. 6...
