ECMlink Swapping 2g MAF with EVO 8 MAF
how much more does the Evo 8 maf flows over the 2G version? 20-25%?
The Evo 8 MAS reports a lower frequency per same air mass flow, it can accurately report higher frequencies than a 2G MAS and it is also a lower restriction to flow. From what I understand about MAF sensors, the difference between the Evo 8 MAS response curve and the 2G MAS curve should vary enough that it would not be accurate to compensate with just a global fueling change. However, with that said, I've seen posts by a certain well known old school chip burner stating that he simply used a flat 25% global change to compensate for the newer MAS on a 2G and a 67% global change to compensate on a 1G. I can't personally testify as to how well this works. I've had a really nice looking Evo 8 MAS just sitting in a box here for about 3 years that I have yet to install and tune with on a DSM.
Edit: This shows the 3G #482 MAS, but the Evo 8 MAS is supposedly the same:
you will not benifit and will need to be retuned.
  • For sale 4G63 6 Bolt ARP Head Studs
    ARP 6 Bolt ARP Head Studs $65 + shipping & paypal fees* these have been torqued onceYou must...
  • Wanted 2ga side markers
    Looking for 2ga side markers
    • Rohitter7878
  • For sale 2g 2G Fwd Thermal Research exhaust
    2g Fwd Thermal Research cat back exhaust
    • ari2gdsm
  • For sale Used Tial 44mm wastegate
    Looking to sell my used Tial 44mm wastegate. Legit Tial gate, verified by Tial. Can send...
    • Anfurnyy
  • For sale 1g 1g stock mass air. 4G63T.
    Stock 1g mass for turbo. Car ran was all stock. Hit in the rear quarter hard. 92 Tsi. Pulled...
