Swapped to manual - still need the TCU/TCM?
da_reeseboy
160
3
Jul 10, 2006
Powder Springs, Georgia
Is there a reason I would still need the TCU/TCM still? The swap was done before I bought the car, so I wasn't around to get the specifics. But it seems that it was a very professional and thorough swap. It appears there was a harness installed for the old Auto tranny plug and run thru the car, and the ECU was even replaced with one pulled out fo a 98 manual GST. So do I still need the TCU/TCM, or can I disconnect and remove it?
  • For sale 4G63 1g/2g Auto Welded Center Diff
    1g/2g Auto Welded Center Diff. Message 702-741-6987.
    • ist dwa
  • Wanted ISO Extreme Psi weighted shift knob
    Easy peazy…
    • James92
  • For sale 1g 91-94 ignition coil
    1g coil with harness side igniter harness. Digging in a box of remains from a yard six bolt for...
  • Wanted 2g Finish My Project!
    I am in need of some big ticket items in order to finish my project. In my engine bay there is...
    • dhssoccer24
