1G Put 2qts in manual trans, still seems low?
Nuzzi
158
5
Jan 11, 2014
Torrington, Connecticut
91 Talon tsi awd mt. Changed the gear oil in the rear end, transfer case and tranny. After putting a full 2qts in the tranny it was still slightly below the bolt hole, is this normal? The manual says capacity is 2qts but to fill until it runs out, so do you guys normally add a little more or is the 2qts enough? Used Royal Purple 75-90 in the trans, and 80-90 Lucas in the rear end/xsfer case.
I put oil in until it runs out of the hole. 2 qts seems about right. One thing to keep in mind is if the front of the car was raised? Transmission needs to be level.
Dam, another $20 qt of royal purple. Thanks[DOUBLEPOST=1408580358][/DOUBLEPOST]Sure enough, it took about another .3/.4qt before it started running out of the hole. My manual sucks. Thanks again.
  • For sale 4G63 1g/2g Auto Welded Center Diff
    1g/2g Auto Welded Center Diff. Message 702-741-6987.
    • ist dwa
  • Wanted ISO Extreme Psi weighted shift knob
    Easy peazy…
    • James92
  • For sale 1g 91-94 ignition coil
    1g coil with harness side igniter harness. Digging in a box of remains from a yard six bolt for...
  • Wanted 2g Finish My Project!
    I am in need of some big ticket items in order to finish my project. In my engine bay there is...
    • dhssoccer24
