"Manual TCU"
92AWDTalonTSI
334
8
Jun 2, 2010
Somonauk, Illinois
I want to take apart an incompatible TCU that I have, solder in a breadboard and make a custom circuit that emulates a TCU. Now the only thing I need to figure out is the pulse attributes for line pressure. I know some people change the line pressure by adding a resistor. Thus making the signal weak and restricting less flow resulting in a higher pressure.
I want to emulate the pulse width for every gear change. Well, at least a close average. So that in first gear it emulates an accurate pressure for a 1-2 shift. So on and so forth. But while WOT do no modulation resulting in a hard shift. I cannot imagine at this moment what the modulation rate would be. But I don't figure something outrageously fast. Maybe in a lower gear? At any rate. I have a not so usable TCU (MD750093) that will shift my car. Albeit at the wrong points. I wonder if I could measure the modulation to get an understanding of line pressure.
Well, at what width is the modulation? I want something I can tie into the TPS output assuming that is how the TCU does it. I can then dial in the width via various pots. Emulating a TCU.
Something like this should work with some modification.
First you need to understand how the PCS works, how the pulsewidth modulation works, and how the transmission uses the line pressure to fully understand what you need to build. You also need to understand why a resister on a PWM signal is not a proper modification.
  • For sale 2g 2G Clear Tail Light Set
    2G Clear Tail Light Set $550 + shipping & paypal feesYou must be registered to see element.You...
  • For sale 98 GS-T for sale
    Here is my 4g63 7bolt fully built for sale
    • Yahdin2G
  • Wanted 4G63 Mpi relay
    Looking for a 95 eclipse gst mpi relay
    • SquatchinGST
  • For sale 1g 92-94 Mitsubishi tail lights
    These were take offs from a new GST on a road race team. I had got boxes of parts leftover...
