Suspension Upgrade Advice
unplugme71
185
3
Apr 21, 2011
Central, New Jersey
The goal of my car is a street/strip setup, not much interest in auto-x at the moment.
I'm looking into purchasing the TEIN Flex coilovers since I can get a pretty decent deal on them right now through someone I know. Plus with the EDFC I can adjust the settings on the fly when i'm on the road vs drag strip. I only plan on lowering the car about 1 to 1.2" to keep a good amount of ground clearance for potholes, etc - and for better suspension travel.
I was going to go with the Koni/GC setup, but it comes out to about the same price by time I add the pillow ball mounts from RRE.
Now my questions are, which camber kits do you recommend? Do I just need the rears? Or fronts too? What other suspension upgrades do you recommend?
First off if it was me i wouldn't get coilovers but that is up to you. My current set up is tokico blue struts with H&R lowering springs, also i have aftermarket sway bars both front and rear (cant remember brand name) car handles like a dream and is lowered about an inch and a half. Also if it is only dropped 1.5 inches you might not even need a camber kit so see if it can be adjusted out first. But definitely get sway bars when you do your suspension.
Also, my rear endlinks need to be replaced. Stick with OEM? Or are there any aftermarket solutions? I plan on upgrading the sway bars to the Tanabe or RM.
