Surge while holding accelerator steady?
bmxrider154
160
5
Oct 25, 2004
Cincinnati, Ohio
no surge at idle, fixed that (injector o rings), but surges when i hold the accelerator steady. pulled 12, 13, 14, 25 out of ecu, which are all included in MAS except tps(14). My theory is fuel pump, plug wires, or a vaccum leak. WOuld check all those but dont have the car yet. 90 gsx. Thanks
yeah its completely stock, check ur spark plug wires and that might be it. I dont have the car yet so i havent tried much. i do need a new MAS so im going to try that first along with the wires.
i tried the mas out of my other car, didnt help. Im just going to get it towed home and fix it here, much easier. I will keep you posted. Does urs only do it around 2k rms? that is when mine does it.
bmxrider154 said:
there is a few cel's, tps, barometric press., and the other two that are in the MAS.
Right, so track those down before playing with the EGR or ISC. If you have access to a logger check those sensors values and check your ECU to make sure you haven't fried the +5 sensor power of ground.
Steve
i know it isnt the MAS, i took it out of my other car and didnt help. tps could still be it, i havent adjusted it to perfection yet. i was just going to swap the isc and egr from other car but i might sell it here in a minute. thanks. i will pull ecu out real quick
http://www.vfaq.com/mods/ecu-harness-1G.html
Check to make sure that there is continuity between pin 101 and 24.
Remove the ECU board from the case and check the back side to make sure you don't have and discolored or burnt traces. Also look closely at the chips on the top right of IC101 for burning.
The TPS, MAF AF, IAT, and Baro sensors all share the Sensor +5 that comes out on pin 23 and sensor ground on pin 24. The sensors can be fine but not getting power or ground.
Steve
continuity is 0.4 ohms. there is a little bit of glazing or clear film on IC101 and also a little bit of cracking on top right. not burning on backside. would the ecu out of my 90 laser fwd turbo 5spd work on my 90 gsx 5spd?
The resistance between the two should be 0 ohms.
The conformal coating cracking arounf the transistor and 8 pin chip in the upper right corner of IC101 isn't a good sign. Can you check the voltage at pin 23. It goes to the TPS (pin 1) and MAF (pin 4) if it's easier to measure there.
Yes, the MD128625 will work in place of the MD145903. It's not a perfect match but it will work. Are either EPROM?
Steve
no i just got the car actually, but not too happy right now. I just got the hood to the windshield, forgot to latch the hood....pissed! how hard is it to change a windshield?
