BigRand
- 2,181
- 32
- Nov 17, 2004
Toronto,
Slowboy racing has several different types. And straighline specialties does too. Just take a look and see what you would want. They have them for the raido bezel or the vent bezel.
If you do buy the vent bezel, go to home depot and buy some foil tape and a small piece of cardboard. Cut the cardbard in the shape of the vent (on the inside and insert it there, then tape off the vent cover so the heat doesn't get to the back of the SAFC. It helps keep it alot cooler.
Oh and the bezel's run for about 55-60bucks.
...get one of them
Uh so I am guessing 97-99 might be different? I don't understand because Howell's website advertises the AF/X ecu's in one generall category 97-99 manual ecu. So I don't know what to go from. The good thing is the computer was free and if it fries no cost. THe bad thing if it does is then I have to find another computer
thanks for the heads up!
My Oil return fitting in my pan is leaking a medium amount of oil and Im not sure if this is relevant or not but, In the past few days after I got my car wideband tuned, the car shuts off after a cold start unless I keep my feet on the accelerator and rev for like 20 seconds then its fine. This has happened like twice before in the past year then it goes away like after a few days. Thats one thing my car was running fine even know rich, then a few days ago it was running pig rich and burning black smoke out the exhaust and running crappy until boost. So I got the car wideband tuned and it was awesome. Then on saturday night i was messing around with an STi when I was at 6psi spiking at 8 and like I should I let the car idle for about 5 min just to be safe. I started driving again and the CEL started to flash but everything felt OK. At Idle it sounds different. Im not sure if its missing a cylinder or what. I am taking it to get fixed tonight but I would like to know about the cold start thing if possible.
