Stumped. Car wont start after HG
ShawnsGarage
354
Jul 19, 2008
kannapolis, North Carolina
Ok guys im stumped. I am far from a newbie to DSMs and have built a few 4g63s with no problems. Until now. I just got my 92 GS put back together after the HG blew. Car ran great before. I had the head surfaced by a well know machine shop in my area and know its straight.
The timing is perfect I have checked it 3 times. Head bolts were torqued in steps of 30 60 80. Pulled the CAS and turned it and all injectors are firing as well as all the plugs. Replaced HG, bolts, cams,valve seals(viton) plugs, wires, fuel filter and still nothing. Car has great fuel pressure. It bucks and spits while cranking but wont start.
I pulled the plugs and they were wet but when I tried to burn the fluid off it wouldn't burn. Seems to have great compression but haven't done a test yet because I don't have a compression tester untill tomorrow. My guess is water or oil is finding its way into the combustion chamber. Any thoughts help because i am stumped
Firing order is correct. Coupler or clamp for what. Im working on my GS not the GST. And its a OEM gasket
Motor firing order is 4321 and thats how I have it. Coil is labled so I know its right.
Any explanation for the Non flammable wet plugs?
I bled the fuel lines yesterday after adding 5 gallons of 93 to the tank. The gauge was below E before I added the fuel. And the car has only sat for about a month. Also tried starter fluid and still nothing.
Not sure where you got that info but it is incorrect. I pretty much know these cars like the back of my hand
its in my heyens manual. there is pretty much NO CAR out there that doesn't have cylinder 1 at the start of the firing order, nor can cylinders 2 and 3 fire one after the other considering the crankshaft design.
and the coil for the 4g63 if you are looking at it from the driver side fender is 4,1,2,3 from left to right
Nightgamer I hope not to cause I have dumped all my money into the head gasket job. cant afford a new head at the time.
92 6 bolt when i said 4 3 2 1 i was talking about the numbers of the cylinders 1 being closest to the t belt
either way 1 and 4 fire at the same time and 2 and 3 fire at the same time thats called wasted spark.
i see that now...and to throw in some useful info here for once, the OEM head gasket is made to crush better so there is almost no chance of leaks anywhere that the head gasket seals so whatever you have preventing you from starting isn't coming from that area at all
Crusin I will PM you about the head in the morning. I checked the spark 2 diff ways. First time I was by myself and did it by turning the CAS with the plugs on valve cover. Had good spark. Then when I had help I took the plugs out and put them on the valve cover while someone turned the car over. Both times all was good
where did you spray the starting fluid?
Tried starter fluid in the intake and in the cylinders. Both time it was a No go
I was specifically referring to a couple or clamp on the intercooler piping being busted, loose, or discounted compounding your problems. Its gotta be something simple.
I mean, if you're getting fuel, and spark.... and you think compression is the issue, you either royally screwed up the HG install, or the timing (bent valves?). Both of which are unlikely if you triple checked everything as stated.
If you are definitely getting spark, and definitely getting fuel pressure, I would suspect something around the fuel injectors, maybe the wires are broken and you didn't see it, or the plugs are busted, something of that nature.
When i had this problem I accidentally put the 2 and 3 plug wires on in the wrong spot, did the exact same thing you are describing here. I would double/triple/quadruple check that too. My car would crank and crank, then a pop, would try to start, and the BANG a big backfire out the downpipe.
Way out there....ECU?
