Stubby Shaft Bolt Size???
tsi1991awd
1,366
6
Sep 28, 2008
Puyallup, Washington
Can someone tell me the size of the stubby shaft bolt for the BSE? I got a new oil pump and new BSEK but it doesn't come with the bolt.
OR can someone actually tell me the part number so I can order it from the dealer?
I don't have the bolt is the thing...that's why I'm trying to find out. Can it be any bolt that size or does it have to be the special looking one like the OEM one?
8mmx1.25mm bolt, ~1.25" long
Edit: Well, maybe not the length. That is if you drill/tapped your balance shaft stub that you cut yourself. Thread pattern and size are the same though.
No, I have the OEM stubby shaft....I'm trying to find the size of the bolt that goes into the stubby shaft. I don't think it is 8mm, the hole looks bigger than 8mm??
This is funny because I had a grade 10.9 bolt in my toolbox...EXACT size I need. 8mm x 1.25 x 16mm...what do you know.
