Stripped Oil Pan Bolts. What now?
Artago
2,094
31
Nov 30, 2006
North Vancouver, BC, Canada
So I stripped 2 oil pan holes.
Timing belt side, the ones that go into the aluminium.
What should I do? Tap and bigger bolts?
What size tap / bolt should I use? M7 or M8?
Tom
I ended up using helicoils which worked out.
When I reinstalled the pan I used large washers on the oil pan bolts to spread the force of the bolts allowing the pan to be tight without warping it. Worked great.
Tom
