psiaddict
- 89
- 4
- Dec 13, 2005
Albuquerque,
New Mexico
This is actually my first technical question here on the board; I hope you all can help me out.
I searched around, but I could not find anything I remember reading something about a similar problem awhile back but I could not find it again
Here is the history:
Okay, I just got my car running again. I just installed a new (used) motor, new (used) transmission, I had to swap the output shaft on the tranny since it was a 22 spline and the T-case was a 23 spline. New ACT 2600 clutch / RRE flywheel. OEM throw-out bearing.
I had the car warmed up and was checking for leaks, everything looks good. I turn the car around in the driveway few times and everything seems good, after a little clutch pedal adjustment, I am ready to drive the car over to the car wash and clean it up. This is when I found the strange problem.
I started out of the driveway but noticed that even though I was on slope, in neutral, I let off the brakes and the car would not roll. I backed up, jacked the car up on stands, all four wheels off the ground and put it in 1st gear, let it go for a few minutes and the put it neutral, now when I try to turn the wheels manually, they will not turn, it is like the brakes are on. I turn off the car for 5 min or so, the wheels begin to turn freely again.
So, it seems like the wheels stop spinning when something heats up, either the Transaxle or the differential maybe it is something as easy as the brakes dragging but the car was not doing it before the engine/clutch/transaxle were replaced
Anyone have any ideas?
I will look at it more tomorrow and see if I can figure out why one single caliper in the system is pressurizing
But it was still a strange symptom to have.
