Stock Theft Alarm
spooln1
121
Nov 3, 2005
carmi, Illinois
I have a problem with my stock alarm system always going off wether my alarm is set or not. and wether my door is locked or not it always goes off. I took out the fuse for it and it still goes off. What i want to know is where are the wires that i can disconnect to disengage the alarm all together? thanks :thumb:
Well on the 2Gs the factory disarm is green with white...negative pulse. Meter this wire while turning the key in the driver door key cylinder. You can also use the passenger door key cylinder which is brown/red (-) in the passenger kick, door harness. *Tie to ground to permanently disable the alarm
But...
The factory arm is green with yellow. Both can be found in the drivers kick panel or the door harness. Meter this wire as well while turning the key in the driver door key cylinder.
You can also use the passenger door key cylinder which is red/blue (-) in the passenger kick, door harness.
Hope this helps
You better check the switch in the hood. that was the reason why my factory alarm used to go off almost everynight waking up my neighbors. until I realized the switch barely touch the hood. what I did was puting a tie-wrap in the switch to keep it close all the time. :thumb:
Other than that works fine....
