stock rubber intake on 20g inlet?
trd-2-dsm
42
Feb 9, 2006
ft. lauderdale, Florida
will the stock intake plumbing fit on the 20g's inlet. i have been told yes but i'm unsure. Also if there is somewhere i could get an aftermarket intake pipe with ricirculation hole i would very much like to know where to find it.
Aftermarket intakes with recirculation tubes are available from:
1. Forced Performance: http://www.forcedperformance.net
2. ExtremePsi: http://www.extremepsi.com
3. DejonTool: http://www.dejonpowerhouse.com
Slowboy Racing also sells Dejon products if you'd like to buy from them. As far as the inlet size on the 20G, these are usually 3" (TD06). If you have a TDO5, your inlet may be 2.5", but the best way to find out is simply measure it.
Hope that helps,
Andy
