What inlet flange on stock turbo?
thjones3
Sep 1, 2006
Reidsville, North Carolina
I could not find this info in my search, although I am sure it is out there somewhere...:(
Is the inlet flange for the stock turbo the same bolt pattern as a T3 flange? i.e Will a T3 bolt up to the stock exhaust manifold on a 4g63? Thanks
The Mitsu is on the left and the T3/T4 is on the right. The t3/t4 can be bolted up to a mitsu manifold with an adapter.
Hope this helps clear it up for you,
Dustin
Dustin
Sorry, but the turbo on the left is NOT by Mitsubishi Motors. It's the KnockOff Version. Notice the wastegate actuator adjustment and compressor housing.
As for the T3/T4 turbo on the right, you would an adapter for it to bolt up on a mitsu exhaust manifold.
It might be a knock off but I just used that pic as an example of the mitsu flange, when I say mitsu I was talking about the flange, when I said t3/t4 I was talking about the flange not the turbo's, and I already mentioned that with an adapter the t3/t4 would bolt up to a mitsu exhaust. You just rephrased what I said.
Dustin
Mitsu Turbine Inlet:
T3 Turbine Inlet:
Thanks :thumb: It looks like from the pics that the adaptor could just be a plate with both hole patterns drilled. I found a good deal for a turbo with the mitsu flange, but it seems all of the aftermarket exhaust manifolds for the 420a have the T3 flange. Does anyone know of one for the 420a that has the stock mitsu flange?
to answer my own question...it looks like thestreetsource.net will put whatever flange you want on the manifold:thumb:
