13g Turbo inlet flange?
TurboMightyMax
Sep 6, 2006
Murfreesboro, Tennessee
I paid $20 for the turbo on the right and I believe it's a 1g automatic transmission turbo.
Where can I get the flange where the j pipe is supposed to bolt up?
Yep, thats a 13g (1g auto) notice the TD 04, manual DSMs have TD 05s. Why do you need a flange for where the lower IC pipe hooks up to? Looks to be the same flange style as my 14B, of course I havent seen it in a while, but still.
Dustin
I've searched on eBay before and couldn't find a stock one. I don't want a fancy polished one. I basically just need the flange.
yes, im guessing you have an a/t 1g with a 13g and want a bigger turbo? direct bolt on sir. LOL.
I actually got a mint 13g for $20 and I'm going to put it on my truck but I can't find any 13g inlet flanges on ebay.
Is the downpipe flange and the oil fitting flanges the same also?
Flange for a TD05
That's JUST the flange, no pipe included. If you want a J-pipe, they're available at nearly every DSM vendor you can think of. Now, since that's made for a TD05 turbo, I'm not sure if it will fit a TD04. Any 1G auto guys here convert to a TD05 and keep their 13g's J-pipe?
Can anyone tell me the outside diameter of the inlet pipe for this turbo?
In other words, what internal diameter of hose would I need if I want to make a boost leak tester to fit on this turbo?
Also, is this diameter for the 13g the same size for the 14b and 16g inlets? If not, what are these diameters?
My car is in the shop now, so it's not easy to measure it myself. :toobad:
Thanks in advance.
