stock fuel pressures?
43 psi for a 2g....for when you set with a fpr set it at 43 with the vacuum hose off
spooln1 said:
thanks, does anyone know about a 1g?Also could they be switched. Say 1g to 2g?
37 psi for 1g. You can switch to 43 psi if yo have to.(BTW switch what the stock presure regulator?) but normally no.
I quoted it from this link
From what I understand 37 is for 1G's whereas 43 is recommended for 2G's. I ran 37 PSI and noticed an increase in knock so I adjusted it to 43 and took it for a drive.
