stock downpipe bolts
lil corb
758
7
Sep 7, 2005
Woodbridge, Virginia
hey I'm removing my downpipe and I can't get the one bolt that holds the shield on, is there any trick to it? cause no wrench or socket will fit.
thanks
It should be a 12mm. I just took mine off the other day and that's what they all are, unless yours has been replaced by something else. I'm not sure if you've taken the fan out yet but it really helps if you do that.
DSMcrazy3 said:
Every bolt was put on, every bolt can be taken off. :thumb:
I belived that too, until I bought my Talon. I had a caliper bolt that I literally spent months trying to take off. Maybe once a week I'd pop the tire off and give it another shot, soak it in PB Blaster, try again next week. I even tried torching it. I ended up having to cut it with a saw.
