stock 6-bolt 40psi boost
TurboAnything
701
12
Jun 6, 2004
Carol Stream, Illinois
Do you guys think it would be ok to run 35-40 psi on 110 on a stock bottom end. Its only a S258 so i think it will be like 550hp. It is not a primary car so if it pops after a while thats ok. I want to tune and get to the track a few times with it this way.
Depending on what head gasket, head studs, and the tune....yea, it's possible. You're going to need to make sure the tune is spot on, otherwise you'll be taking part in a high speed engine disassembly.
i've spiked 40psi on a 35r and im fine...i usually run 28ish psi on pump daily as it is but i think i finally popped my headgasket yesterday bc i usually start my car in the morning and let it warm up....i go back out to my car 20 minutes later to see a cloud of white smoke :(
