1G STM Fast Idle Air Valve Bypass Plate
If you are wondering about wiring ECMtuning has a ECU pinout, and there is a thread on here that lists all of the plugs and the wire colors that goes where on the plug. That can at least give a good idea of how the wiring should be.
Posting pictures always helps when trying to diagnose stuff though.
I know seen that in this chiltons book. The only thing tho is i dont havve a obd port theres sumthing plugged into it and i think its for the data logging cable. Im not surre. And speak of the vacuum tester it just came in the mail!! VERYYY HAPPPY!! I WILL BE CHECKING THE CAR TOMMRO!!
I just made tester, was only like 20 bucks to make and it is plenty good enough for my application for finding vacuum leaks, and when I turbo I probably wont be going real high in terms of psi.
  • Wanted 6 bolt NT water pipe
    • chrisman287
