Steering Wheel/Airbag Question
mnetwork
1,017
Feb 25, 2006
New Milford, New Jersey
I'm about to get a new steering wheel because I am so tired of this big ### 2g wheel. The only thing is I don't want my SRS light to come on. Does anyone know how to rig it so that it doesn't come one? I searched for this, but it didn't come up...
Take out the bulb. That would be the easiest way. As soon as the car has battery power and see the airbag is unplugged that light will come on and you can't turn it off. I'm sure there is some way to wire something in to fake it out but it doesn't seem worth it unless you are going to be putting the old wheel back in some day.
I want to keep the light so that I can still have the passenger side monitored. There has to be a resistor or something you could put inbetween the two airbag wires to trick it. I just was wondering if someone has done it. Momo sells a hub/srs delete kit, but not for our cars.
Actually people put a resistor (have not done it, can't tell you what size either) in line after the airbag is removed. But yes, removing the light is the simplest way.
Yeah, I just want someone who has done to tell me what size resistor to use. Someone here has had to do it.
I guess I could just measure resistance between the two airbag wires on the stock airbag and then get that size resistor? Sounds like it'd work right?
Be careful!!! When YOu measure resistance, your meter sends some electricity between probes, to check resistance. I'm not sure if it won't deploy airbag :rolleyes:
Just be careful!
I was actually thinking the SAME thing two days ago. I had an idea to extend wires to the airbag and do it from a distance just in case...
i would just take the bulb out if the resistor was to go out over time the light would come on, so if you take out the bulb you will never have to worry about the light coming on again
for the talon and eclipse i do believe it is a 2.2ohm resistor but double check and measure the ohm resistance
I tried measuring the resistance of the airbag yesterday. The multimeter showed .4 ohms.. does this make any sense?
