Steering boot doesn't go back on?
nastyleak
93
Oct 14, 2010
Mobile, Alabama
Okay I'm done searching and cutting my hands. The passenger side went on eventually after a sufficient number of bad words. The driver side is an unholy nightmare and the posts I found including this one: http://www.dsmtuners.com/forums/newbie-forum/161082-torn-steering-rack-boot.html simply explain the general process. So I've seen the pics and that looks like something that would tear the boot like a sharp fish hook. There has to be a better way to do this. None of the 3 auto parts stores have anything except the pics. How can you possibly get this thing on?
The driver's side is absolutely the worst. I probably spent an hour on it, like you cussing and cutting up my hands. Boy do I wish I had small hands at times like those.
All I can do, is offer some sympathy and tell you to keep trying. If I recall, I did try to lube up the lip a little bit and instead of those silly metal zip ties, I just went and got some hardcore 100+lbs. test. zip ties. Still good, years later.
That's funny you used zip ties because these actually came with zip ties. Maybe I'll try to stretch it onto something and make its hole a little bigger.
Okay I got it I borrowed my sons toy bowling pin and stretched it onto that, then let it sit in the sun for 1-2 hours and it went on easily. I would suggest not getting the Raybestos Professional grade steering boot-bellows. These have to be thicker than most which is good now that they are installed but not good for easy installation.
    • george bromwell
    • pma1123
    • Sdcryan1
