Startup Problem
I'm running into the same issues but I'm pretty sure mine is ecu related. (leaky caps) mine surges and sometimes stalls with a new isc. Check for vacuum leaks, bad isc and ecu. Also troubleshooting basics, air fuel and spark.
CEL 12-MAFS...
My stock maf plug was cut so I got one from a junked car and just connected each wire with its corresponding color.
Either the maf is bad or there is a boost leak on my intake?
what else can set off the CEL 12 MAFS???
The car idles better with the maf unplugged if that helps diagnose it.
