2G Starts idles rough stalls clueless
Might seem a little obvious but taking the engine apart a bunch i tend to forget simple stuff time to time.
The first time i experienced that a couple year's back i just simply forgot to plug the MAF sensor in after a blt.
No check engine light or code starts is ok for legit a second or two then idles rough and stalls not sure what is going on. Recalibration wideband.
Is your wideband in the front or back? What happens when you give it throttle? Will it run then?
