Starting Problem Help ASAP!
bluebomber
Banned Member
81
May 18, 2003
Its a 90 talon tsi bought the car with a broken timing belt, changed the head, and timing belt, car started fine, but as soon as i turned it off it wont start again, its getting spark , but 9i think it is getting to much gas, took off the plugs and they are dripping with gas. The next day It will start right up and do the same problem. So my problem is soon as its shuts off it wont start no more. The car was sitting for 2 years i think the gas has no octane. New wires, plugs, fuel filter, injectors, regualtor, what can be the problem.
I suspect you should drain the tank and put some new gas in there. You might be able to re-use it a gallon at a time when filling up. Try to flush the lines before starting again.
Cheers,
GTM
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
  • For sale 2g Clean title
    • FirstTimeDSM
