HELP starting problem
626freak
64
Dec 31, 2007
new castle, Indiana
im posting this for my friend his 93 eclipse gsx the tranny went bad, but the car still ran. anyways he said it sat for awhile then one day he tried to start it and it wouldnt crank over so he put a new battery in it and still wouldnt crank over it just made a clicking noise when he tried to start it
Give any opinion or advice you have(all will be appriciated)
Tell your friend to check the connections on the starter. They may have corroded from sitting. Also just for the sake of it try to turn the engine over by hand. One other trick is to have someone try to turn the key while another person taps on the starter solenoid with a hammer. Tap lightly!! You are not trying to drive a nail into a board you are just trying to jar the starter. This trick can also work sometimes if your fuel pump quits working. You can tap on the tank firmly and sometimes jar the pump into working again. I have done this and it can work to get you home. It sounds like the starter is stuck but make sure the connections are clean and tight. Keep us posted.
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
  • For sale 2g Clean title
    • FirstTimeDSM
