starter question
stealth13
136
Oct 10, 2008
calgary,
I installed my new clutch and everything seems to (working except for the fact that the starter just sounds like its spinning and doesn't grab the flywheel.. Could this be the starter relay causing the starter not to push the gear out before it spins?
Had the same issue on my N/T. Check your grounds.
i doubt it would be the starter relay try turning your engine by hand and if that doesn't work pull your starter and take a pair of jumper cables and hook the power up to the power and the ground where the bolts go then take a wire and run it from your ignition switch on the starter and put it on the positive of the battery if it still doesn't kick out its time to get a new starter
we tried jumping it with the cables and it seems like the thing is spinning but the top part thats supposed to push into the flywheel ISNT
haha my bad i should have read that a little better. ya if it aint extending out i would try another one. what year car?
