stalling issues after cruising...
dnhieu
1,927
17
Aug 16, 2004
panama city, Florida
so recently i was running my car hard and it started stalling after coming off driving. if i push the clutch in while the car is in motion it just stalls. if im at a dead stop and start it up it idles fine.
so far i have checked timing (dead on), and replaced the isc with 3 different ones i have had laying around. the throttle body is grounded good and the wire on top of the throttle body is plugged in. i recently rebuilt the throttle body and the voltage read at .63 volts on my LINK. the only thing i have not done is boost leak check it even tho im sure their isnt any major ones.
thanks in advance
david
What's your base idle RPM? you may need to adjust the AIR screw if you just rebuilt, or perhaps a leak @ TB gaket? generally leaks cause Idle surging and high idle NOT stahling. Check for leaks @ or near DV (BOV) and Intake pipe to Turbo/MAF etc...
Good luck
thanks man. idle is set at 1k trough my dsmlink. biss screw is set accordingly. the car ran fine before running it hard. after i ran it hard its been idling crappy...
:hmm: Back to the drawing board. I'll consult my Mitchell n see what it has to say or not? LOL:D
