stage 1 questions, 190 or 255lph Fuel Pump?
noz
298
Oct 8, 2003
oroville, California
ok i got everything listed on the stage 1 except for a fuel pump.
with the bigt28 im going to use, should i go with a 255 or 190 fuel pump?
i won't have enough money for injectors and afc yet.
will a 255lph Fuel pump make me run rich? cause any problems?
or should i use the money for a supra smic upgrade?
190lph pump is plenty.
After you get the money, get the IC before injectors and AFC, as your stock SMIC will heatsoak rather quickly.
1993eclipseGS said:
Are they the same price? If they are, Just get the 255?
Why not go with the 190, which shouldn't overrun the stock FPR, and will be plenty for a T28-powered car? With a 255, an AFPR is usually needed.
I'm T28 powered and I have a rewired 190 and it's more then enough, at least at the boost I'm running. If you have the money for a AFPR, then you could just get the 255 and not have to worry about upgrading later.
