ssac 1/g nt throttle body
lq1driver
206
Dec 17, 2007
painesville, Ohio
Hey guys I was wondering if any one running an ssac fmic has any one installed a 1g n/t throttle body and what all did you need to do it? im getting a decent boost leak from the welds of the upper pipe that bolts to the intake so i figure why fix it when i can up grade it
Hey guys I was wondering if any one running the ssac fmic has installed a 1g n/t throttle body and what all did you need to do it? im getting a decent boost leak from the welds of the upper pipe that bolts to the intake so i figure why fix it when i can up grade it
I have this, but also have a smim so the setup is a little different. Get a 2.5 to 2.75 45* bend silicone coupler, that may work for you. The n/t is a 2.75 inlet.
The 1g turbo tb has a 4bolt flange, the 1g n/t tb is the same except there is no flange you use a silicon coupler. It's a 2.75 inlet. Do a search on ebay you will see detailed pics.
What did you end up doing to get the SSAC UICP to work with a TB that requires a coupler not 4 bolt flange?
