Has anyone ran a 1g NT throttle body?
my98gsx
Supporting VIP
794
290
Aug 14, 2005
Wappingers, New York
I am doing my rebuild for the season now and I ran into a small problem. I wanted to get rid of my stock elbow off of my throttle body, so I was looking through my boxes of car parts. I found the perfect solution, I have a 1G Non-turbo 63mm throttle body. Looks exactly the same as the 1g one i was using for the past few years, only it has a factory neck on it, not a bolt on elbow.
I was looking through alot of old posts and people do run these, my question is can you just bolt it on and have fun with it? I saw some people did have theirs re-built, and trew in turbo seals, and others said they were just fine the way they were. I figure if you can but a mustang throttle body from bbk which isnt made for boost, you should be able to use the non turbo one with no problem...
Is anyone running a non-turbo 1g without the turbo seals in it?
I been running the non turbo throtlebody for about 4 years now. I did have to replace the seals two years ago, but have had no issues since than.
A couple reasons why there nice too run:
No more tb elbow , gasket to leak and added weight
They don’t taper down
You can remove your intercooler piping easier
Well for the week I drove my car, it held up great for me. I rebuilt mine and ruined my turbo seals I tried to put it. Apparently the turbo seals are just a hair larger than the holes in the turbo. I ended up doubling up #7 o-rings on both ends with grease. Holds boost great.
Only problem is you'll either need to weld more pipe on the UICP or get a huge coupler. It's probably safer to get pipe welded on for an extension.
thanks.
I wonder... since the 4g37 TB is about the same ID as the 2g, will there be any drawbacks to switching? I have both here, could be interesting. It'd be nice to be able to t-bolt a coupler on there as opposed to using the stock stud/bolt setup and gasket. With my TB elbow, its a pain to tighten/loosen the bottom right bolt.
When I get my car back from the body shop, I may experiment a bit if no one has any objections.
