ss clutch line install
eclipse1999
99
Aug 10, 2006
new york, New York
I'm installed a used ss clutch line from the slave to the hardline. I found out the banjo bolt on the slave is too long. Does anyone know what size and length of the banjo bolt i should get?
Also i left my clutch fluid empty since yesterday. Hope it didn't dry. Will there be big problems?
Well what I can tell you is measure the size of the current bolt, measure the gap and subtract the two and that should give you roughly the size you need.
"Also i left my clutch fluid empty since yesterday. Hope it didn't dry."
That made my brain hurt, what exactly did you do? You will have to bleed the whole system regardless because you are putting a new line in but I don't get what you meant to say.
  • Wanted 6 bolt NT water pipe
    • chrisman287
