SS Braided Clutch Line and inconsistent pedal feel
dsm023
69
3
Mar 3, 2004
Orlando, Florida
Just did a complete clutch job:
Fidanza flywheel
Act 2600
Installed 1 of these SS lines at the same time and now the pedal feel changes. It seems to be go from firm to firmer as I drive. Is it normal for this to be happening?
What kind of SS line are you using? Full? just the part that replaces the rubber hose?
Check your Master and Slave for leaks. Also try bleeding it again, somtimes just when you think you have it bled properly, the car likes to mess with you and shows you otherwise. ;)
Using RREs that elimantes the reservoir. Master and Slave are brand new. So this isn't normal then? Time for EVEN more bleeding then...
What you are getting is pump up. If there is no free play at the top of the pedal you will get this. To gain free play at the top of the pedal, loosen the lock nut on the top of the pedal and turn the cruise control switch that is attatched to the stud the nut is on. Turn it so the pedal will be able to raise higher. From doing some research on it myself this is what i found out. Hope this helps.
