SRS Exhaust problem
bowens1414
123
Oct 30, 2012
Bradenton, Florida
Ok guys, just got my srs catback off ebay and im having a fitment problem. now there are 2 styles from what i see for the gst.
This one
SR s Catback Exhaust System 95 99 Eclipse Talon GST | eBay
or this one
SRS Stainless Catback Exhaust System 95 99 Mitsubishi Eclipse Talon GST JDM | eBay
I got the first one. my biggest problem is that the flange that connects to the cat is a 3 bolt flange. as for the idiot that previously owned my car and cut that flange and clamping the cat to the exhaust, i do not have that matching flange on the cat. regardless of the fact i know i have to order a downpipe and want to run catless. will i have to get a test pipe to make up for lost space or will the catback make it to the Downpipe? and any downpipes out there with the 3 bolt flange?
There are down pipes with a 3 bolt flange if you are going to go catless there is no reason to buy a test pipe my 3 inch down pipe goes to where the cat should be and i bough 24 inch stright 3 inch stainless pipe and welded it to connect both pipes . To anwer your qeustion yes they make them and yes you have to make up for the length of the cat when putting these on with out a cat.
"OBX Downpipe 95-99 Mitsubishi Eclipse GST Down Pipe 3"]OBX Downpipe 95-99 Mitsubishi Eclipse GST Down Pipe 3 this is the one i used i dont use a 3bolt flange but i have seen them in the past couple of months when i was looking for my exhaust.
    • klipschaudio
    2g pass front rocker corner
    • dsmmario
  • Wanted 1g Fuel Pump Hanger Assembly, MPI Relay
    Current one is rounded off, kinked and crusty. Looking for a good condition 1G AWD hanger and a...
    • Gabe92RTTT
