Squeking from front right wheel well
bob123131
457
Dec 20, 2004
winona, Minnesota
The other day i was drivng and i cna here this squeaking noise from in side the fendor. It sounds like when u need new brakes but this is a constant sound when ever im moving. Does this mean i need new brakes also. I have never had it where it always does it jsut when u tap the brakes. Or is something loose and shaking do u think?
yea, this happened on both of my rear brakes because i use my ebrake alot. my thought would be that either the caliper or the sliders froze up. either way you will need brake pads, and depending on how long this has been happening, you might need to turn your rotor, or buy a new one all together.
when you do this, dont forget to lube evry piece of your brake, ur sliders, compress the piston back into the caliper, and put lube on the contact points as well as some disc brake quiet on the back of ur pads.
