Knock From left wheel-well
sirspoolalot
Aug 23, 2008
Chelmsford, Massachusetts
hey guys,
i'm getting a knocking sound coming from the left wheel-well area and i don't know what it is. the knock gets faster when i accelerate but the sound doesn't get louder/quieter relative to my speed. When i turn the wheel left or right the knock goes away. also, there's some fluid leaking on the ground right under the left wheel-well that isn't oil because i've checked my oil everyday since i got the car and it hasn't gone down. I'm thinking that maybe it's a power steering leak there or something. I think the two things might be related because they are coming from the same area. just hit me back with some ideas as to what it could be and how i can go about diagnosing them. Thanks :)
edit-- i can feel the knock in the gas pedal, steering wheel, and brake. but i don't feel and vibrations on the clutch pedal.
strut mounts and ball joints.
that was my problem i had.
but sounds like you have an axel going bad. that might be boot grease. is it thin or thick fluid?
Also make sure that the lug nuts are tight, i had the same thing and i thought it was the wheel bearings and turns out my lug nuts were loose and my tire flew off.
well the fluid that i was leaking was Power Steering fluid and i was told that there is a gear in there that could have gotten shredded up because there was no fluid in the well. could that be what's causing my knock?? i couldn't tell what color the fluid was because whatever it was mixed with the dirt that's on the engine and shit so it just looks black.
