noise comming from left wheel
0r1landoDSM
213
Nov 10, 2010
Long Island, New York
when, drive straight the wheel makes a rubbing noise and as i go faster the rubbing noise goes faster too. its goes like "rub,stop,rub,stop" and as i go faster the cycle goes faster too. when i turn the wheel left it stops, when i turn the wheel right it stops too. i stood in front of the left wheel and pulled it forward and backward didnt feel any play. when i hit about 60 or 70 mph on the highway my steering wheel shakes and it quiets when i turn left or right and stops shaking
if anyone has the same problem then its a bad wheel bearing
sounds like a wheel bearing jack up the front of the car grab the tire at the top and bottom and shake the wheel and see if it moves you wont always feel the movement with the tires on the ground
