squeaking sound prob?
eclips3_xs
79
Jul 23, 2008
Burbank, Illinois
hi guys i got a squeaking sound coming out of the engine bay. Its squeaks constantly while driving and stood still. I found a solution but i cant fix it or make it go away. When i press the clutch stood still it goes away or if aim driving and just put my foot on the clutch pedal just a little tipsy pres like it goes away. how can i fix it?
^+! Yep, throw out bearing (tob) also called clutch release bearing. Unfortunately you have to pull the tranny to replace it. You don't have to replace it immediately (like stop using the car or anything). You can run it that way quite a while if you can stand the noise, but eventually you will have to replace it. If you're planning a new clutch soon this would be a good excuse. :D
No way holy s**it i just replaced the clutch with used tranny like 5000 miles ago maybe i didn't lube it enough.
  • For sale 4G63 Groden alum rods. Set of 4 with ACL bearings
    Groden aluminum rods. Set of four. 22mm small end. With ACL race rod bearings. Locating...
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
