Squeaking sound?
gswOwner
Feb 3, 2009
Trea, Indiana
Ok so when I push the gas at low rpms it's very quiet but a squeak/squeal noise comes. Not sure if it's under the hood or from the driver tire/suspension-
Besides going to a shop is there something to look for, the belts are fairly new done at a shop.
Thanks
Tighten the belts. I've gone through a few sets already and shortly after I put each set on I had to retighten them because they had stretched a small amount but enough to make them squeal. Its pretty easy to do so just try that and let us know.
JD
tighten or replace the belts. i had the same problem, and i tightened up the belt and it was gone.
  • For sale 4G63 Groden alum rods. Set of 4 with ACL bearings
    Groden aluminum rods. Set of four. 22mm small end. With ACL race rod bearings. Locating...
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
