Spyder Strut Bar Fit HELP!!
hsk8te2006
182
Jun 9, 2007
Ann Arbor, Michigan
Hi,
I'm interested in adding strut bars to my GS-T spyder, but I can't find anythign that tells me for sure if I can install all 3 (front uper, rear lower, rear upper) on a GS-T spyder. Does anyone know if all three can be installed on a GS-T spyder withotu having to cut through anything cosmetic to make it fit (I don't want to do that if I can help it). Do I need to look for particular brands or models in order to fit a spyder (ratehr than a coupe)?
ANy advice on what to look for in a strut bar?
Anyone who knows please share!
hsk8te2006
Front upper will be fine, they are the same as the coupe. Rear upper will not work, the bar will hinder the top from going down. I dont know about the lower.
I tried to put one in the upper rear, lets just say it does not work. As for the upper front lower front, and lower rear you're good to go. I already done it on mine.
